GsiTurbo
Dátum registrácie: 2. Decembra 2020, 16:27
Príspevok od používateľa GsiTurbo »
Admin napísal: 2. Decembra 2020, 23:39 There are differences in EU and US/Canadian software :( This update will not work for you :(
Thank you for the reply. I just purchased a new SD card and will test the update over the weekend and post results.
hedal napísal: 2. Decembra 2020, 22:07 Hi.
I'm from Poland.
I have the same problem with my Genesis. Diference is that i imported car from US, but anyway can not use Navi....(displays Palm Beach :) )
I am not sure about version but hope there will be somone smarter who can help you. I also have concerns whether the North American system will adopt the European version. if you gain any experience, let me know.
Regards
Palm Beach sounds nice and warm right now :-) Yes, if this update works for me, this should also work on the Genesis (nice car, btw). I am also trying to connect via a friend of mine with this fellow from Russia that makes custom Roms for Kia/Hyundai including US/Canada vehicles. Look here, it claims to be compatible with Genesis G70 https://www.drive2.ru/o/b/553706635118249220/
Elantra Sport 1.6 T-GDI 7-DCT 150kW 265Nm
hedal
Dátum registrácie: 30. Novembra 2020, 16:18
Príspevok od používateľa hedal »
I have taken out SD card from car and tried to copy but none of my laptops reads it.
Isn't it strange? Do you think,there are diferences between hyundai SD card and standart SD?
Can i use standard card?
Nope, theres no differences. Check side of SD card if its locked.
hedal
Patrik napísal: 3. Decembra 2020, 17:14 Nope, theres no differences. Check side of SD card if its locked.
Card is not locked, anyway it shouldn't make a difference if you only read card....
So idk :( I havent any problem with original SD card. I was updated Tucson 2017, 2018, 2019, 2x i30 2019 with original memory card..
hedal napísal: 3. Decembra 2020, 18:55
hedal
So maybe there is an option to install only android auto?
GsiTurbo
Well, I have managed to determine that I need Gen 4.0 software. Does anyone have a torrent link? The other link is mega slow.... thank you in advance! :-)
SOLVED
FilipD
Dátum registrácie: 2. Januára 2021, 13:04
Príspevok od používateľa FilipD »
Dobrý den,
chci si stáhnout aktualizaci pro i40 2015+, ale v software se objevuji 4 složky (part1, part2 atd...) a v mapacáh až 12 part.
To mám vše stahovat, anebo stačí jen tu poslední.
Díky
Ano, treba. Ked nasledne zacnes rozbalovat Part1, tak to rozbali vsetko dokopy do jedneho kompletneho suboru. Nebudes to musiet robit postupne.
HoSpeLL
Dátum registrácie: 7. Januára 2021, 21:25
Príspevok od používateľa HoSpeLL »
Hello everyone.
I am desperately looking for USA Gen5 Mobis software. My Ioniq 2020 doesn't have navi. Is there someone her who has it?
