Ahoj. Modely bez navigácie nemajú aktualizácie.
- Bushik1415
- Dátum registrácie: 1. Apríla 2021, 12:17
Razumel. Najlepša hvala.
- Dátum registrácie: 25. Mája 2022, 16:03
Ahojte. Kupil som ojazdeneho Tucsona 06/2016, 1,6 GDI. Radio nebolo asi nikdy aktualizovane. Neviem ani kde mám pozriet verziu a a aky je tam software. Poradte mi prosim cim si viem vylepsit toto radio. Aspon nejakymi novsimi mapami. Alebo tam viem nejako dostat apple car play? Pripadne kupit niekde novsie radio? A co mi vedia aktualizovat original v Hyundai? Ma tam zmysel chodit? Ďakujem
Ahojte, ešte otázočka, exituje to zapustené rádio so soft. veziou aby sa tam dało dat apple car play? ci ten gen 5 je už to vyvysene radio po facelifte ? diky
Aktualizaciu vies vykonat aj sam. Staci nainstalovat Navigation Updater a tam vyhladat svoje vozilo a stiahnut najnovsie mapy.
Na tvojom radiu nepojde zrkadlenie telefonu. Mali to az posledny kusy vyrobene par mesioacov pred faceliftom - MY18. Riesenie by bolo najst uz novsie radio s podporou a vymenit plug/play.
- Dátum registrácie: 27. Júla 2022, 13:01
I have a big problem with updating my radio navigation in Hyundai i30. The head unit (96550-S0100) is 8 "installed from the i30N version to my Hyundai i30 (my car version is the i30 PDE wagon 2017 compact). This head unit is working fine. All the modifications that were needed for the new head unit were done. Software version what is the head unit with is PDEN5DR.EUR.SOP.V085.180104.STD_M. Unfortunately, I can't update this software. After downloading the software for I30N PDEN.EUR.SOP.V126.220421.STD_M and trying to install it, I get a message from the head unit that reads: "The maps SD card is not compatible with the software version. Insert correct SD card. '
Where is the mistake. How can I update this head unit?
maybe it caused becouse you have sw version from 2018... mabyte its needed to install some other "middle" update...
try download manually this version from 2020 - you have headunit GEN5 MOBIS
viewtopic.php?f=48&t=52
Thanks I will check this.Admin napísal: ↑28. Júla 2022, 10:55maybe it caused becouse you have sw version from 2018... mabyte its needed to install some other "middle" update...
I have a question yet. Do I need a genuine Hyundai SD card to update the software?
no, its not necessary
I downloaded the older version 2020 from the torrents for GEN5.x MOBIS 2020. I uploaded the files to the SD card (FAT32). I went to the Car. I put the card in the slot and started the car. I got the message: Navigation is not available check the status of the SD card. And then nothing happens. When I go to the settings, where the update button is and I press this button I get the message: Insert the removable memory with the update files and try again. The end.
I have no idea how to update this head unit anymore. Something is blocked. I do not know what. Do you have any other ideas? Maybe because the unit is transplanted from the I30N to the I30 comfort wagon? Is it possible?
I also can't get to the android system files in this head unit. (2x 7 times pressing the screen in the screen saver tab). I don't know how to get into android settings to unlock this unit. Help
